Wizard Nebula
Giant easy guider help
Started by Meters, 11/04/2004 02:13AM
Posted 11/04/2004 02:13AM Opening Post
Hi, I am new to astrophotography and need some help. I am using a Meade 10" LX200 with an Olympus OM-1. I recently bought a used Lumicon Giant Easy Guider but I have not been able to get the OAG to focus very well. Has anyone in this group had any experience that they can share with me? Also, I am have a most difficult time in focusing the camera as well. Any recommendations on that. Thanks, Mike
Posted 11/04/2004 03:15AM #1
I can't quite understand your question. Just as an overview, what you have to do with an off axis guider is to attach the camera to the main tube, and a reticle eyepiece to the off axis side. Then bring the camera to focus as well as you can. Then locate the guide star of your choice, and move the guiding eyepiece in and out of its holder until the star becomes sharp.
Having said that--
Just what do you mean that the off axis guider does not focus well? I am interpreting this to mean that you got your camera in focus, but that you cannot get sharp stars in the reticle eyepiece. There are two cases of this:
--that you cannot get it to the focus point (i.e., you are moving to focus and the star is getting smaller and it never quite gets there before you run out of focuser travel--in this case your eyepiece bottoms out or extends beyond the eyepiece holder),
--or that it does not look sharp when you do get it to focus (the stars get smaller and smaller, and then start to get larger, but never get really sharp).
If it is the first, you need more travel in your eyepiece holder. You need to shorten the drawtube or lengthen the eyepiece, depending on whether you are running out on the way in or out of the drawtube. You can add an extender to the eyepiece. To shorten the tube, you may need to cut off a piece. One alternative is to find an eyepiece whose field stop is closer to the end of its tube. Also, you may have a parfocal ring that has been installed that needs to be removed to give you extra travel.
If it is the latter problem--you move into focus and then out, but never get sharp stars--you are probably talking about one of the difficulties of off axis guiding--You are working with a star on the edge of a field, and by nature the optics are not as sharp out there. Or you may have an eyepiece that is somehow out of whack. One nice thing is, of course, that the star you are using to guide does not have to be in good focus--It helps, but it is not an absolute.
Now, as far as getting the camera in focus in the first place--that is a whole 'nother skill that needs a thread of its own.
Posted 11/06/2004 04:57AM #2
Mike, I used a giant easyguider on my old C11 for quite a few years. I found that I needed extension tubes for the guiding eyepiece so that I could back the eyepiece out and still be able to secure it for guiding. you can obtain 1 inch extenders that screw into the filter threads from Lumicon.
You will need a different guider EP setup for each focal length. As I recall, I could set mine up for about f/6.5, f/5.5 and f/4.
What focal length are you trying?
Camera focus is a tough nut to crack unless you have a fine, clear screen to work with. You might check the camera suppliers to see if they have a microscope phototography screen for your OM-1.
I have a NIKON "C" screen in my NIKON F camera that has a clear center area with crosshairs.
Bill
