VDB 142 Elephant Trunk HOO
Guidescope Suggestions
Started by tschonis, 12/30/2002 09:38PM
Posted 12/30/2002 09:38PM Opening Post
Hello,
I am currently looking for options for a guidescope for my LX200GPS 8". I am thinking about maybe an ETX-90 OTA to go on top or maybe a Celestron 90mm refractor. Any fellow 8" LX200 users have any ideas for me. Thanks.
Taylor
Posted 01/01/2003 05:11PM #1
It is my experience that any reflector is a bad idea for a guidescope unless you do some modifications to completely remove any possibility of the slightest mirror shift. I have a 10" LX200 and I use Losmandy mounting rings (very solid) and a 90mm Astro-Physics refractor specifically designed to be a guidescope. You want it to be as solid as possible. Also....you need your focal length of your guidescope to be at a bare minimum at least half of the focal length of the primary scope. Use a barlow if necessary. Basically....solid as possible(refractor always better for guiding), and long focal length comparable to the primary scope. Hope I have helped.
Steve
