Lumicon Easy Guider
Started by Alex McConahay, 05/19/2002 01:55PM
Posted 05/19/2002 01:55PM Opening Post
Hi all,
I'm thinking of buying a used "Lumicon Easy Guider" for use on my Celestron 9.25. The device has a four inch long 1.25 i.d. tube off the pick-off mirror, and a two inch main tube with some optics in it. On the camera end of the main tube, there are three set screws, but no other adapter. ON the telescope end of the main tube, there are three set screws. That end of the tube seems to be just a bit larger than two inches for the first quarter inch. (all measurements by eyeball)
Just what do I have here? Where can one go for better information. I cannot find anything at Lumicon website, and a Google search turned up stuff for the Giant Easy Guider, but not this one.
It seems I am missing some end pieces (Telescope to guider/ Guider to T-adapter). I am familiar with Off axis guiding, having done it with a 1.25 version.
All advice welcome.
Posted 05/19/2002 09:26PM #1
Yes it sounds as if you are missing a few things. The scope end of the guider should have a threaded adaptor that would screw onto the back of your SCT and then be held into the guider with the 3 screws you mentioned. The camera end should have an adaptor that is specific to your camera and will be held in place with the other 3 screws.
Give Lumicon a call, they should have everything you need.
Robert.
Posted 05/20/2002 04:06AM #2
The one you are loking at may be for a newtonian and it didn't come with SCT rings.
