Jay Messeroff
Lunar & Solar Transits
"Magnification" in Astrophotography
Started by stelenes, 02/11/2003 06:56PM
Posted 02/11/2003 06:56PM Opening Post
I have really managed to get myself confused with a question that seems it should have an answer under very reasonable assumptions:
What will an "image" on a 35mm camera film "naturally" measure for 0.5177ยบ arc "using" a small refractor (60mm objective, F=900mm with 32mm eyepiece [28X]) and would good optics define a single answer?
I hope this isn't a naive question but apologize if it is. I posted a less specific version of it in a photography forum where I attempted to make what I thought were very reasonable assumptions to define the problem. The answers are generally not taking into consideration the astronomy concept of magnification. The question I am posting here has tree words in quotes, because they would seem to need better definition. Here goes:
(1) IMAGE: needs to make use of the magnification provided by the eyepiece and be reproduced on film even if it is virtual at the same distance the eye would view it.
(2) NATURALLY: means resulting from the optical system alone as if it were perceived by the eye in a normal e.g. 28X scope. No further enlargements of detected images (whether film, CCD, etc.) by any means, whether during viewing or in PhotoShop or the lab.
(3) USING: I am having a little trouble understanding how the virtual image dimensions match on perception of eye vs. record on film, but it is possible and done routinely, right?
The link for the photo forum question follows, if you are curious, where the answers have been quite kind from some outstanding photographers, but leave me feeling that their photo enthusiasm overshadows a little better astronomy-centered perspective.
http://www.photo.net/bboard/q-and-a-fetch-msg?msg_id=004WEA
Please help me!!
Posted 02/12/2003 04:19AM #1
David,
I cannot quite figure out what you are asking.
In general, most of us say that if you divide the focal length (in mm) of the imaging optic (telescope)by 50, you will get the "power" of the scope for a 35 mm camera. A 900 mm lens gives you approximately 18 power. This 50 is the best match in perspective of the normal one power that the eye sees. That of course is why a 50 mm lens is considered "normal" However, the image size on film is not necessarily related to the size that your eye would see, and of course, the amount you blow up the print, or project it on the wall, and then how far from the wall you are sitting or how far you hold the print from your eye will determine its relative magnification to your eye. In short--the term "magnification" does not really apply.
However--are you asking what size is the image of a full moon on 35 mm film using a 900 mm lens? You will get an 8.2 mm image.
Does that answer your question?
