How long should the shutter be open in order to photo Mars? I'm using a K1000 and 140mm f/5.7 refractor w/ 2x barlow. I've taken previous photos ranging from 10 seconds to 2 seconds. Unfortunately I brought my photos to Walgreens and none of the photos printed. Side note - don't bring film to places like this. Only 6 of 24 photos turned out and only m45 was decent. I would have thought one of the Mars images would have worked. Anyway, input would be very appreciated.
Mars photo question re: exposure?
Started by thoth11, 09/02/2003 05:49AM
Posted 09/02/2003 05:49AM
Opening Post
Posted 09/02/2003 01:31PM
#1
Don,
Don't know your answer for the exposure--but it sounds like you are way overexposed. Remember--Mars is a daylight object! Maybe lots of power on it--but it is noon on Mars.
As for Walgreens or any other mass developer. You may have some wonderful photos there. Check the negatives. The problem is in the printing. They print as if it were a daytime photo--trying to make the sky blue. They may not know what an astrophoto looks like--and have no idea how to get your negative to look like one. It is not their fault--they are doing what they are trained to do.
Posted 09/02/2003 02:30PM
#2
Hi Don,
With the setup your using you won't be able to record Mars at any more than a fraction of a millimeter across at the film plane. So you won't be getting much detail--- but I suppose it's possible to *just* capture the polar cap. You'd probably need an effective focal length of 3000mm or more to make it worthwhile.
You didn't mention the film your using,you would need to get as fine-grained film as possible for such a small image on film as Mars, and that means slide film like Fuji Provia 100F, either the new Velvia 100F or Astia 100F, or the Kodak E100 films. Even the finest grained color print films can't come close to competing with these. But if B&W print is OK, then Kodak Tech Pan would work fine.
The exposures you attempted were _way_ too long. Even with the relatively slow 100-speed films I've mentioned, exposures will range around 1/60 to 1/30 sec with the setup your using. If you boost the scope up to f/50 or so with eyepiece projection, then your in the 1/4 to 1/2 second range.
If at all possible, it would be far better to use a digital camera afocally, or a webcam with your barlow.
John Boudreau
http://home.comcast.net/~jeboud/astro.htm
John Boudreau
Posted 09/02/2003 09:04PM
#4
Thanks for info. I do have a Nikon CP 880 w/ 18mm wide angle ep & adapter. I'll use that for Mars photos and I guess try my hand at long exposure astrophotos. So far I've taken decent images of M16, M17 and M45. The longest exposure on 400 speed film has been 15 minutes on M16 & M45. I'll try for 30 to 45 minutes though I think a guidescope would be very helpful.
Is it possible to photograph a Martian moon? A photo taken last week was overexposed. I used a 25mm TV plossel and 3x barlow and had the shutter open anywhere from the 2 to 10 seconds I mentioned in my post. It looks like Phobos. Any chance? I'll find the photo and scan it here at work tomorrow, then post. Maybe I'm just seeing a reflection of light. BTW, focal length of scope is 800mm.
Thanks for help, info.
Funding Member
Sponsors
- Vernonscope
- FocusKnobs
- Desert Sky Astro Products
- Matsumoto Company
- APM-Telescopes
- astronomy-shoppe
- Waite Research
- AstroMart LLC
- OMI OPTICS USA LLC
- BW
- RemoteSkies.net
- Anacortes Telescope
- kwtelescope
- Astromart Customer Service
- CarbonScopeTubes LLC
- BBLABS LLC
- SellTelescopes.com
View all sponsors
