Wizard Nebula
Parafocal or not...
Started by WV3V, 09/07/2005 05:58AM
Posted 09/07/2005 05:58AM Opening Post
Hello all and thanks for all the great help out there for astrophotography! Here is a question, that's basic in nature and probably just being overlooked by myself. I'm using an OM-1, with the Lumicon GEG (LX-200GPS) and found out this weekend that I can't seem to focus through the OAG eyepiece, without the focus being totally off through the camera viewfinder. What gives? I have the 3.5" extend tube on the GEG, but am wondering if I need something longer, if they make it.
I've read about using a lower power eyepiece, but then the 12mm lum. reticle I have won't work. At the time, I was using the standard 26mm eyepiece. Any suggestions would help. I tried to remove the eyepiece and only when I got it about 1/4 inch out of the extension tube did it seem to focus (holding it by hand)and be in focus in the camera view finder. Thanks for all the help. Jason
Posted 09/07/2005 02:06PM #1
What you are running into is common. There is no reason for an eyepiece completely inserted into an OAG to focus at exactly the same place as the main imager. You have to pull the eyepiece out (don't insert it all the way in) to get it to focus, or, if it is already too far out, you have to shorten the tube on the OAG.
Posted 09/07/2005 07:13PM #2
Check out this article... especially the "Mode Report" section.
http://www.astrocruise.com/geg.htm
Getting to focus with the off-axis guide port depends on where you have the focal reducing mirror. If the lens is behind the prism, closer to the camera, in the f6.5 position (see Phil's notes about the true f-ratio) then you need an extension beyond the tube that comes with the GEG. I used a diagonal as a spacer when I guided manually, even then you must slide out the diagonal a bit. With an autoguider, I took off the lens element of a 1.25" barlow and used that as a spacer/extension tube. If the focal reducing lens is in front of the prism, in the f5 position, you don't need an extension tube - but the vignetting can make this configuration iffy depending on your setup.
Changing the eyepiece you're using won't help - the one you're using should be fine.
