VDB 142 Elephant Trunk HOO
PHOTOSHOP QUESTION
Started by deccles, 11/16/2004 05:41PM
Posted 11/16/2004 05:41PM | Edited 11/16/2004 05:42PM Opening Post
:S
I'm sure there is a simple answer to this question, but I'll ask it anyway.
I have a photo of a double cluster which I processed and saved through photoshop 7. When I saved the pic, it was converted from a jpeg format to a .psd format. In jpeg in was approx. 350kb in size, but in psd format it's now 16mb. I would like to email it to friends, but the new format is WAY too big. How do I change it back to a format with less memory. I tried putting the jpg extension on it, but photoshop returned an error when I tried to re-open it. Any help would be appreciated.
Clear Skies
David Eccles
Posted 11/16/2004 06:02PM #1
Hi David,
The most likely cause of this is the format of the image. Open the image and then go >Image >Mode and see whether the image is 16bits/Channel or 8bits/Channel.
In order to save the image as a jpg, it must be 8bits/Channel.
If this does not solve the problem, try >flatten image<.
Hope this helps.
Cheers,
Maurice
Posted 11/16/2004 07:11PM #2
Thanks Guys, I'll try it out. grin
Posted 11/16/2004 07:53PM #3
When you processed the file you may have been using layers. Go to layers>flatten image, and then try to save it as a jpeg.
