posting a photo
Started by deccles, 01/06/2006 10:39PM
Posted 01/06/2006 10:39PM Opening Post
To All,
I attempted to post a photo earlier and had some difficulty. Specifically, I mae the photo size in PS 7.0 to be 7 inches by 5 inches and approx. 497K. After posting, I opened the attachment and all I got was a small box with nothing in it. I'm assuming my size adjustments made it too small. What is the proper size in inches and in file size?
Some photos I've seen here take the entire screen and others display in a average size window.
Thanks for your assistance.
David
Posted 01/06/2006 11:08PM #1
David,
I have no problem posting images that are 1000 pixels (10") on the longest side so your photo is not too big. I do however try to keep the size between 100-200K otherwise viewers with slow connections may give up trying to see your work because of the long download. I can't find any restrictions on file size but 497K may be too big. Also, I believe the image must be jpeg. (jpg.) or gif. to display on this site. If this is not right I hope someone corrects me.
Try saving the file in jpeg format around 200K or less then upload to this site.
I hope this helps - Cal
Posted 01/07/2006 12:29AM #2
David,
Instead of inches try pixels. The reality on the Internet is many folks (over 1/2) browse on monitors set to 1024 X 768 resolution. I see several photographs posted here that require you to scroll around to see them. I am not sure of the logic in that. Most want to see the photograph in its entirety not a bit, then scroll, then a bit more, then scroll... With all the navigation on this site - across the top and bottom and down both sides you need to keep your photographs to 640 X 480 or at most in my opinion 800 X 600.
In Photoshop or any other image processing program set the image size to 640 X 480 pixels. Save the image as a jpeg at medium resolution as the majority of the high resolution data is lost in the compression anyway. The resulting file will often be under 100K and be pleasing to the viewer and accepted by the Astromart upload tool. If someone just has to have the high resolution image they can ask you for it. Even the best images selected by Herb as the POD are put up as a small 200 X 200 pixel (or less) thumbnail linked to an image that opens to the approximate dimensions I mentioned and are kept in the 100K size range.
Kent
