The easiest way, if I understand your setup correctly, is to make a parfocal eyepiece.
Focus and aim your imaging camera on an object at infinity. Remove the camera. (Here, I am assuming you now have a 1.25 eyepiece holder waiting there attached to the lens.) Insert one of your favorite eyepieces, and focus by moving it in and out of the holder. (Best eyepiece would be a short focal length with wide field of view and reticle if possible.) Mark where it sits when in focus. (If you have a parfocalizing ring then put it in--of course if you have such a ring, you probably already know how to use it and this explanation is redundant!!!). Next time you are setting up, just use the eyepiece set in as far as that mark (or parfocalizing ring) in the lens, find and focus, and then remove the eyepiece and replace with camera.
