Hi Thomas
I shopped for electronic muffs about a year ago and read a lot of user reviews, and the $60 Howard Leight Impactâ„¢ Sport Earmuff seemed better-reviewed than many of the more expensive units. I think review 'stars' tend to be higher for less-expensive gadgets that do not have obvious serious problems, compared to more-expensive gadgets that are relatively defect-free. But many of the more-expensive electronic muffs had too many user reports of failures and mis-performance for my taste.
The Howard Leight electronic muffs have worked fine for a year. The amplification seems relatively clean, and the sound-reduction seems immediate enough to protect against sound pain from gunfire. I've only used them outside, and they seem adequate by themselves for protection on non-loud guns.
I've always used earplugs + muffs even with the old passive muffs, especially with loud guns. Hearing is worth protection.
One earplug I've used since the 1980's, initially for sound protection on loud music stages, is the etymotyx ER-20 (which last a long time and cost about $15)--
http://www.etymotic.com/ephp/er20.aspx
These do not have the absolute max sound attenuation, but they are comfortable and they have a relatively flat frequency response. They don't have a 'plugged up' feeling in the head.
Most high-attenuation earplugs are not flat, and attenuate high freqs more than low freqs. For music use, from my experience an earplug is useless unless the frequency response is relatively flat. There can also be annoying 'rumble' problems with non-flat frequency response earplugs.
The ER-20 flat attenuation is also (to me) more pleasant for protection from machinery noises or gunfire, because it is easier to understand speech when the frequency response is flat.
For ultra super loud sounds, an ER-20 or a typical muff is not sufficient protection alone (in my opinion). But using both together works well.
Another not-expensive earplug I've used since the 1970's are the 'sound valve' type. Sold under various names. Here is one apparently aimed at the shooting market and perhaps more suitable than a generic sonic valve.
http://earplugstore.stores.yahoo.net/health-enterprises-acu-life-shooters-impact-ear-plugs.html
The plug is not quite as comfortable if used for many hours on my ear canal, compared to ER-20, but it doesn't get annoying for a couple of hours. They may fit other folks better. My ear canal may be a little smaller than average.
They have a small metal cylinder containing a captive silicone diaphragm. Under low-noise conditions the valve is 'open' and the plug only has about 6 dB attenuation. Loud sounds flutter the valve against the seats, stopping loud impulsive sounds with a much higher attenuation.
They are good for hammering or machine noises because they don't affect hearing except in presence of loud noise. The stock sonic valves are not so good for gunfire (by themselves), because they don't seem to work fast enough to stop the first loud impulse. The item listed above may be better. Haven't tried that model.
They are also not good for loud music protection for a musician or soundman, because the valve fluttering causes too much intermodulation distortion for hifi sound.
But I use them a lot along with earmuffs when shooting. The extra 6 dB attenuation adds significantly to the muff attenuation, and if an awesomely loud gunshot happens close by, the valve increases attenuation more if the muff can't handle it alone. Since the low-level attenuation is only 6 dB, it is a little easier to hear speech with passive muff + sonic valve. Hearing speech is mostly impossible with passive muff + ER-20. You might as well be stone-deaf.
The combination of electronic muff + earplug is very good IMO. I can crank the gain of the electronic muff loud enough to offset the attenuation of the earplug, so that hearing is as good or better than normal when there is no shooting. I can hear folks talking down at the other end of the range. But on each gunshot, the electronics mute, and I get the full protection of muff + plugs, which ought to be in excess of -30 dB.
