14 inch Mak-Newt on 1200 mount
Started by RolandC, 12/15/2004 10:32PM
Posted 12/15/2004 10:32PM Opening Post
Hi all,
Here is a picture of a 14" Mak-Newt on our 1200 mount. This instrument, made in Germany with Russian optics will be going to Chile for remote imaging of the southern hemisphere. I've had fun doing a bit of imaging with it these last two days. It is impressive what you can capture in 10 seconds, and even in 1 second.
Roland Christen
RolandC's attachment for post 20815
Posted 12/15/2004 10:43PM #1
Wow!! That is one mighty impressive setup. Roland, your mounts, much like your telescopes are works of art.
Posted 12/16/2004 01:29AM #2
Roland,
Those rings seem mighty thin to support what must be a fairly heavy scope based on the size and number of the counterweights. Or are they more like straps to just hold the OTA against a cradle ?
David Simons
David Simons
Posted 12/16/2004 05:07AM #3
Is this one of the 3 f4 and f4.5 mak-newt's that Markus made up recently? Particularly, is this the one that was for sale on Astromart?
Kurt
Posted 12/16/2004 11:35PM #4
Roland,
How flat is the imaging field of this scope? Will it need additional optics to cover an STL11k? Thanks.
Loke
Posted 12/17/2004 01:06AM #5
Roland, Very awesome set-up indeed! Just beautiful. I'm surprised at how compact this set-up appears, so I'd assume the FL on the Primary is quite fast. Kind of like a "Fastmax" on Steroids. Seeing Marj with the scope, I thinking Marj is about 1", or so taller than me, I'm figuring she's about 5"-9", correct? (I'm about 5"-8") Nice that you got to test/play with this awesome toy before you had to part with it! Mark D.
