Advice needed - CPC 9.25 vs CPC 11
Started by Paul Smith, 10/18/2005 03:43AM
Posted 10/18/2005 03:43AM | Edited 10/18/2005 04:15AM Opening Post
Hello,
My permanent pier / deck addition is nearly complete and now I need to decide which scope to purchase. It will primarily be used for visual use in Alt/Az mode. I reside on a hill on the west side of a city with a population of 60k. On nights of good seeing, the Milky Way is easily visible. I'm also able to see Mizar's 4 mag companion.
I've learned through research that the 9.25's have a more contrasty image. I'm curious to know things such as:
Is an 11" scope is too much for "in town" use due to light pollution?
Will the larger scope be more affected by unsteady skies?
Does the light gathering capability of the 11" make a significant difference? Any thoughts, ideas or opinions would be greatly appreciated!
Thanks in advance,
Paul
Posted 10/18/2005 01:35PM #1
Paul Smith said:
Hello,
Thanks in advance,
Paul
This is how I see it (much of this is relative to each individual user, but...)
1. A bigger scope will always show you more. You can always "stop down" using a Hartman mask, or some such, a larger scope, but you can't make a small scope larger. I opt for getting the largest OTA your mount/body can handle.
2. Unsteady sky's.... This has been debated to ad-nausea... Many folks - including some very experienced amateurs and even "pro's" think larger scopes magnify the "problem" (this is the argument I hear most from the APO folks on why 80mm scopes are nicer then 11" SCT's). Then again there are others just as qualified who don't agree (at least 1 S&T articles in the early 90's stated as much) - I fall into this camp myself. The way I see it, why limit yourself to the bad seeing day's - always get a scope that will show you the best view for the best day (within limits - see #1). Again, you can always stop down if you find you are sensitive to unsteady skies.
3. Is the 11' better then the 9.25" - yes and no - Optically bigger is better given all things equal. A good 11" scope with experienced eyes will show more detail then the 9.25 - size just wins IMO. With that said I stuck with the 9.25 for several reasons over the 11" - lighter - I am able to carry more toy's on my mount (I tend to piggyback and side by side all sorts of toys), Easier to move around - more compact, A slower Primary F/ratio then any other prod. SCT - which in theory gives flatter views across the FOV - an advantage for astophoto stuff (let alone easier to manufacture accurately) - and may be the biggest reason these 9.25 sct's have such a good optical rep.
If I were strictly an observational amateur I would opt for the 11"...
