celestron c5
Started by docdavidb, 09/26/2008 03:06PM
Posted 09/26/2008 03:06PM | Edited 09/26/2008 03:09PM Opening Post
I obtained a used celestron c5. It has a loose corrector plate. Is there a given protocol for correctly centering the plate (say, some home-built spacers at the perimeter) or must this be sent to celestron. Is believe I read about this being a somewhat common problem with a certain generation of c5's.
Also, the focus knob on this C5 moves VERY freely. It moves the mirror and focusing works fine, but I was surprised at the ease of movement. Is this normal?
Thanks for any insights,
David B
Posted 09/26/2008 09:26PM #1
David B
HI:
Older Celestrons had considerably easier focus action than the old ones. The way to center a corrector is via little paper shims. Were there none in place?
Uncle Rod
Time on your hands?
Posted 09/27/2008 12:25PM #2
A newbie follow-up for my C5:
I removed the retaining ring and the corrector plate. I tried to fabricate paper shims for the perimeter but found no satisfaction there, so I used some appropriate diameter rubber O rings. These 0 ring sections (about 1 cm in length) were placed at four positions at the perimeter of the corrector plate. The retaining ring was then installed.
I found the use of cotton surgical glove liners to be nice hand covers for handling the corrector and, in fact, performing all of the above. I viewed Jupiter last night with the reconstituted scope and so far so good. Must get a new battery for the dot finder.
David B
