CN16 doesn't slew my NexStar 8i SE
Started by BlacksTAR, 02/26/2005 03:18PM
Posted 02/26/2005 03:18PM Opening Post
I recently bought a used CN16(#93963) for my Nexstar 8I SE.
The CN16 appears to be working because it connects and gets the Time, Date, Longitude and Latitude. Aside from these information that's all it does.
I was under the impression that the telescope would slews to the appropriate alignment guide stars for confirmation.
I went throught the menu options on the key pad(remote) and made sure GPS was "ON". The only options I have for alignment is "Auto Two-Star, Two-star, EQ North and EQ South"
Thanks in advance
Andrew
Posted 02/26/2005 06:23PM #1
Andrew: It sounds to me as though your telescope is only offering you the non-GPS methods of aligning. Apparently you've gone to the "Utilities" menu and made sure the GPS is "on" under the "GPS on/off" submenu. Then when you go to the basic "Ready" condition you can get GPS alignment in one of two ways: Either punch the "Alignment" button, or punch the "Enter" button and then select the GPS Alignment alternative. If your scope doesn't select any alignment stars for you in the alignment process, something must be broken. Sorry I can't help you fix it. Good luck.
