Reposted with Bill's permission:
ADVERTISEMENT
Hi Guys
As you already know I have been doing nothing but testing scope since my return. I had about 12 1026 ready to go out Thursday and just wanted to star test them that night. All star tested well, but I thought I would take a peek at Mars with one. In the Mars image was yellow halo that extended about 1/2 the diameter around the planet. It was not perfectly circular and changed in shape as the planet drifted thru the field. I have seen this in many Achro scopes ( Always blue) and it is greatly influenced by the seeing conditions. I went back and retested all 12
and the same conditions occurred.
I was beginning to think it saw caused by the very high humidity, but just to be sure ( Before I shipped them the next day ) it wasn't the scope I brought out my own 1278. No halo was visible in the 1278. just a nice
sharp image. Now I had a problem that I could not figure out. I stayed up till 3 that night working on the cause.
Today I tested the lenses on the foucalt tested and they are perfect. I had already contacted the factory and had them working on the problem from that end. They have an awesome optical bench that produces any test patterns and artificial stars. I told them to test on a -3 magnitude source as the halo was not visible on my test star. They were able to reproduce the results on the bench above-1 magnitude. The only problem was now both of us were
baffled as to the cause.
It looks as though after I went and found one of the first
prototypes that we may have found the problem. All of the prototypes have only a mg fl multicoat. The prototype showed no yellow halo. We now think the Broadband coating
is causing the problem. The factory is now testing three lenses to confirm this, one with no coatings, one with mgfl and one with broadband. Just to make the problem
harder to find the broadband coated 1278 and 1538 work perfect.
The factory I have chosen to make our scopes is great, they said they will do what ever it takes to fix these scopes. You may also know that we have a diagonal problem. The factory is working all weekend to remake new rear housings molds for the diagonals.
I want to thank you Guys for your patience as I will settle for nothing but perfect performance on these scopes. They have in stock enough glass to replace all of the 1026 lenses. ( I had already told them that I will need to reorder soon as almost all of the first order is sold) We are working on several possible fixes for the diagonals give me a couple of days and I will tell you our results.
Bill
Burgess Optical
865-769-8777
ADVERTISEMENT
Hi Guys
Bill
Burgess Optical
865-769-8777
