"Hi Guys
As most of you know we have lens problems with the 1026. The problem
is
surface 2 was incorrectly generated. There is no problem with the coatings or
polish of the lenses. The factory is already making 200 new lenses and should
finish in two-
three weeks. In defense of the company that is making my scopes the glass was
delivered to them with the wrong curves on side two.
The other problem is the 2.0" diagonals ( This affects both scopes)
new castings were made late in the manufacturing to improve the cosmetics of
the diagonal. They also recessed the diagonal in to the back plate to help
maintain better collimation. When they did this it threw the aliment out of the
diagonal. All 400 diagonals have been air freighted back ( At the factories
expense $2,800.00) They have been working nonstop since to make new back plates.
This problem also will only take 2-3 weeks to correct. The new lenses and
diagonals will then be FedExed
back to me.
One interesting note to the diagonal problem, this problem
has accidentally solved the problem we had in making a collimatable diagonal. I
kept two of the diagonals and modified them for user collimation. They work
wonderful. We will put this diagonal into production later.
Bill
Burgess Optical
865-769-8777"
is
finish in two-
back to me.
Bill
Burgess Optical
865-769-8777"
