Mike Angel
Rosette Nebula
Lunt Pressure Tuner Question
Started by tbennett, 03/09/2012 07:38AM
Posted 03/09/2012 07:38AM | Edited 03/09/2012 07:41AM Opening Post
Hi All,
There's a 60mm H-Alpha scope (B1200 - Pressure Tuner - Crayford Focuser) on its way that I'm planning to attach to a Celestron C5+ mount. This is single-arm fork mount driven by a small 9V battery with the arm on the left side looking from the back (eyepiece end). Could someone tell me if the pressure tuner cylinder is on the left or right side of the OTA? I've seen pictures where is appears on either side but some of the pictures may be mirror images. Maybe the focuser rotates allowing either configuration? I'm hoping the cylinder is on the right so it will work with the C5+ mount.
Thanks, Tom
Posted 03/09/2012 01:37PM #1
the Cylinder is on the right side, but you can always easy switch, the focuser is attached by 3 set screws, open them , you can rotate the focuser as you want :-)
best wishes
Markus
clear skies
Markus Ludes
APM-Telescopes/Germany
Posted 03/09/2012 06:54PM #2
Tom -
You can rotate the components into any orientation you wish. There are set screws to allow for this. I changed out my set screws with stainless steel thumb screws, eliminating the need for those pesky, easy-to-drop allen wrenches!
Steve
