Aligning the SmartFinder
Started by Mta472, 04/02/2006 04:23PM
Posted 04/02/2006 04:23PM Opening Post
Recently I purchased an LX90 with LNT and SmartFinder. The Autostar was not communicating with the LNT module so I had to remove the battery and clean both sides of it with a pencil eraser. When I reassembled the unit I found that the LNT module worked fine. However no matter which way I turn the two adjustment screws I can not center the red dot for the SmartFinder on the lense nor can I get it to align with a light - centered in the scope - about 200 yds away. The red dot is way over to the right of the center of the lense and the light the scope is pointing to. How can I get the red dot to align in the center of the lense and point at the light which is centered in the scope? The lense is pushed all the way into the holder - I heard it click into place as it should. Thanks....Mike
