Meade Capture view binoculars
Started by sthater, 06/12/2003 09:17PM
Posted 06/12/2003 09:17PM Opening Post
Just received my Meade Capture view binos and I have a few comments. First of all, the specs are different from the literature. The objectives are 30mm, not 22(apparently not stopped down either), and the close focus for the camera is only 32 feet instead of 49 feet. The camera must be focused for infinity because while the bino's focus like normal porro prisms, the picture focus is not adjustable. It comes with an adequate soft case and can store 48 Hi res(640x480)images. You must download via the enclosed USB cable and the included software is adequate. You must remove the batteries between uses or they will drain in a few days. You then lose your stored images. Comments?
