Got back from work to find that the stock had delivered the baby! I broke out laughing when I found an envelope with a birth certificate and a bubble gum cigar! I connected the CAA (Camera Angle Adjuster) and then the 2" adapter, then an A-P diagonal. I used a BT Tech losmandy plate which worked out very nice and mounted the whole thing on my DM-6. I have plans for DSLR astrophotography, but could not resist a visual test. The night was clear and steady, so it was great to take a quick look. I have to say I was delighted by the views- crisp and sharp. I did not need the 2" extension adapter that came with it. The scope paired up well with all my eyepieces- I tried out my Televue WF 24mm, Ethos 13mm, Nagler 9T6, Radians 4mm, 5mm and 6mm. No problems with any of these eyepieces. Absolutely pristine views. The Ethos was particularly a very nice match and yielded incredible wide field views. My notes: 1. correction was better than my TV-85 2. In the ET cluster, the color difference between the two "eye" stars was immediately apparent. 3. double double in Lyra split very clean with 4mm, 5mm and 6mm Radians. 4. This scope has the size and feel of my former Tak Sky 90II, but I think a tad heavier. 5. The micro focuser worked well- very smooth with no issues.
Attached is a pic with a 7x50 finderscope attached to the scope to give you an idea of the size. After tonight- I think I will use this scope for visual too!
Clear Skies,
Ivan
Clear Skies,
Ivan
