RICHARD COFER
Idas filter for fs102
Started by Wray, 08/19/2005 03:29AM
Posted 08/19/2005 03:29AM Opening Post
I'm using the camera angle adjuster and the 5.9 reducer. What do i need to connect an Idas lpf to this setup? and I guess while I'm at it what size filter? Thanks, Tim
Posted 08/22/2005 06:01PM #1
Tim:
Filter sizes (and locations) for the FS-102 are as follows:
67mm filter at the camera angle adjuster
48mm filter at the wide T-mount
48mm filter at the extension tube (2")
48mm filter at the diagonal mirror
This information is from the handy table hosted on the Anacortes site smile
http://www.buytelescopes.com/container.asp?dest=/manufacturers/takahashi/filter_selection.htm
Steve
Using Filters with Takahashi Refractors
Filters usable with the following models:
FS-60C 62mm filter at the objective cell
52mm filter at the camera angle adjuster
30mm filter at the C2X
SKY-90 95mm filter at the objective cell
FS-102/128N 67mm filter at the camera angle adjuster
FSQ-106 112mm for the objective cell
FS-152 48mm filter at the extension tube (2")
82mm filter at the tapered ring
82mm filter at the reducer
82mm filter at the flattener
82mm filter at the aux ring (prim focus)
TOA-130 48mm filter at the extension tube (2")
48mm filter at the extender TOA 1.6x
48mm filter at the 35mm flattener
82mm filter at the 67 flattener
67mm filter at the F5.3 reducer adapter
Common use: 28mm filter at the LE oculars; 48mm filter at the LE-50mm ocular; 48/49/52mm filters at the filterbox for the extender.
NOTE: Filters do not always fit as described due to the thickness of the anti-reflection coating on the screws.
