Mewlon 210
Started by JRock 457, 07/30/2003 05:31PM
Posted 07/30/2003 05:31PM Opening Post
Hi everyone I was thinking about purchasing a mewlon 210. But before I did there were some questions that I had that no reviews could answered. My first question is, I have heard that there is a coma problem with the mewlon 210 when one would use an eyepiece such as the 31mm nagler or 35 panoptic, is this true? My second question is I have heard that the mewlon 210 does not hold collimation as well as the bigger brothers such as the 250 & 300. Does anyone know if this is true or not?
Thanks, Jimmy
Posted 07/30/2003 07:58PM #1
I consider these both of these statements to be "myths" that are perpetually forwarded about the M210.
My M210 holds collimation very well. It is, however, more sensitive to precise collimation than my C9.25 was. So-so collimation in the C925 yielded only a softer image; in the M210, so-so accuracy yields a distinctly poor image and you can actually see the misalignment of the sight tube to the secondary.
I regularly use a Pentax XL 40mm with a 2" AP MaxBright, and my eyes don't find the coma in visual usage from the scope. The ep might have slight off-axis astigmatism at the edges, but the center of the axis is where my eye is looking. Others may be more critical observers, however...
Overall, the M210 is a very easy to use scope for its aperture that yields outstanding images.
On the Tak Uncensored Group you will find additional discussion on these exact same questions.
Posted 08/02/2003 02:25PM #2
Hi Jimmy,
I have a Mewlon 180, which is comparable, and can say that the scope holds collimation very well. It is very sensitive to collimation for planetary or double star use, but if you follow the instructions in the user manual and learn to make SMALL tweaks, achieving critical collimation is not hard. I regularly split sub-arcsecond doubles (last night elongated and may have split one at 0.7" near the zenith). It will come from TNR close enough that a small tweak of the secondary adjutment screws is all that is necessary.
The one caution is that there is some mirror flop noticeable at high power double star work. I conquered this by collimating at zenith so that the deflection of the primary is small until I get to elevations low enough that the seeing is destroying things anyway. The mirror flop only becomes noticeable in my scope if I collimate using a star at low elevation and then flip the tube over.
Hal Coward
