Mewlon 250 Collimation
Started by cscappaticci, 11/04/2009 11:59AM
Posted 11/04/2009 11:59AM Opening Post
Hi, I've collimated Celestron SCTs before, but am going to collimate the secondary of my Mewlon 250 for the first time since I received it. It's not totally out of collimation but it definitely needs it (I can see the out of focus image (in and out) out of round at 80x, I usually collimated my SCTs until based on Legault's paper at 500x or higher). My question, I know there are three sets of push pull allen head screws and you loosen one slightly then tighter the other slightly. Here's a picture of the front of the Mewlon.
I downloaded the Mewlon 300 manual from the Takahashi Which of the set of screws is the push and which is the pull (brass or silver allen head screws)? Unfortunately the manual in PDF form is missing all of the diagrams. It alos cautions not to loosen the "pull screw too much" which could cause the secondary to fall out and hit the primary! Kind of concerned there....
Any help appreciated.
Chuck
Posted 11/04/2009 05:38PM #1
M250s can and do fall out of collimation. For the most part they stay in collimation after reset and hold it very well, even when jostled during movement or shipping. My recommendation is to talk to Fred at TNR. He can talk you through the collimation process and even send you some graphics to help you visualize the process. The M250 is easy to collimate and it can be done in the daylight. Once you learn how, it becomes second nature. Seriously, talk to Fred before you try it, or you'll be very upset with yourself.
Scott Busby
A.K.A. Reconair
Carpe Noctum
Mortal as I am, I know that I am born for a day. But when I follow at my pleasure the serried multitude of the stars in their circular course, my feet no longer touch the earth.
- Ptolemy,c.150 AD
