Jay Messeroff
Lunar & Solar Transits
Need your opinion Tak Epsilon 180ED
Started by ivanong, 03/12/2007 05:06AM
Posted 03/12/2007 05:06AM Opening Post
Hi, picked up a used Epsilon 180. Put my Canon 20Da on it and took a 10min exposure of a star field in Gemini.
Attached are two pics. One of the whole uncropped frame, another highlighting 3 magnified regions of the photo. Things look decent in the center, but at the edges stars are badly elongated. Is anything wrong?
And one more question: when defocused, is the image of the secondary supposed to be in the center or slightly offset? Mine is offset.
Thanks, Ivan
ivanong's attachment for post 36170
Posted 03/12/2007 05:07AM #1
And here are 3 magnified regions. Things look pretty bad near the peripheral of the frame.
Ivan
ivanong's attachment for post 112289
Posted 03/12/2007 06:43AM #2
Thanks, Ivan
It may be a little out of adjustment. It appears the
focal plane is slightly tilted, so that top and center
focus, but bottom is a little off. Problem could also be
in coupling to camera, or in camera itself. Maybe you could
try to rotate the camera, and see if the pattern stayed
oriented with the camera.
I do not have this model, but from what I know about the
design, the secondary should be offset. It will be offset
away from the focusser. This offset is typical in fast
Newts.
Posted 03/13/2007 03:09AM | Edited 03/13/2007 03:10AM #3
Thanks Klaus and John for your helpful hints. To me, it boiled down to 3 things. The first was the wide mount T ring not sitting well and hence the off axis problems. The second was improper cool down. The third which I hope was not the case was pinched optics giving rise to astigmatism.
So tonight I made sure the OTA was cooled down 2 hours. I made sure the wide mount T-ring was absolutely secure. I am happy to say that the resultant frames are pin-point edge to edge. Besides the huge dust bunny on the frame, I see the illumination is not even. I think this is more of a problem of the Hutech IDAS LPS filter I was using.
Klaus- did you get the 1:10 fine focuser? I do not have one-I'm thinking of getting it. Focus is definitely very sensitive on this puppy. I had to focus 3-4 stars to get it right.
This is M37 by the way.
Ivan
ivanong's attachment for post 112313
