NJP trick
Started by gregbradley, 06/18/2007 11:12PM
Posted 06/18/2007 11:12PM Opening Post
I have 2 observatories and they are at slightly different latitudes. So I have been trying to minimise the polar alignment time when switching between the 2.
In the southern hemisphere it is much harder to use a polar alignment scope as the pole stars are incredibly dim and just are hard to spot.
I found I can put a laser collimator (Antares newtonian $25 laser collimator - the type that fits in a 1.25 inch eyepiece holder) on the metal end of the polar alignment scope of the mount and it projects and hold it there by hand and have it square. It projects a beam through the polar alignment scope (when the OTA is to the east or west) and this beam hits the ceiling of my observatory. I marked it with a piece of black electrical tape so next time I simply adjust the mount until the beam hits the same spot and I should have achieved a repeat of the previous aligment saving me from having to do a fresh drift alignment.
I think it would be a great feature on a mount to have a built in laser projector that can shine on a wall/ceiling much like a lot of power tools do these days.
Greg.
Posted 06/19/2007 12:26PM #1
Greg,
Is your mount a GOTO? If so, have you tried PoleAlignMax to help you with your polar alignment? I don't know if it works in the southern hemisphere, but if it does, give it a shot. It has helped me salvage more than a couple of imaging sessions that would not have been so because of snow or mud - I usually image from my lawn, where I can see Polaris. When the lawn is snowy or muddy, PAM allows me to image from my patio (I can't see Polaris from there).
HTH,
Eric
