Wizard Nebula
Re: Alternative Dust Cap for FS102
Started by Sailcat, 09/28/2003 04:26AM
Posted 09/28/2003 04:26AM Opening Post
You know, James, you're right. There is a market for a light-weight, close fitting replacement for the man-hole cover Takahashi installs into their FS 102 scopes. Maybe someone will recognise the market potential and produce one out of aluminum or plastic for $20.00 to $50.00. I know I'd buy one!
Best wishes,
Walter
Walter Locke
"The Fearless Spectator"
There are 10^11 stars in the galaxy. That used to be a huge number. But it's only a hundred billion. It's less than the national deficit! We used to call them astronomical numbers. Now we should call them economical numbers.
Richard Feynman
US educator & physicist (1918 - 1988)
Posted 09/28/2003 04:29PM #1
I was thinking it might be worth taking the original cover to something similar to Tap Plastics and ask them to duplicate it in sturdy, 1/4" thick plastic. Three stacked discs glued together; the first would be able to fit inside the dew shield, the second would sit on top of the first at barely larger than the OD of the dewshield, and the third would be about one to two inches across and would serve as a handle. A little bit of felt and a touch of glue and we're in business! I wonder if they have plastic in Takahashi green...?
Walter Locke
Richard Feynman
