Jay Messeroff
Lunar & Solar Transits
taka em10 USD sideral rate too fast
Started by moutinho, 02/16/2007 01:27PM
Posted 02/16/2007 01:27PM Opening Post
Hi,
I am trying to measure a EM10 USD PE and the sideral rate seems too fast. I am not using a non regulated 12V. I have measured its output voltage without any load as 14V. I will try a regulated power supply. Can the problem be the power supply ?
Andre
Posted 02/16/2007 04:40PM #1
You are probably not polar aligned (Alt axis too low). See my response in the CCD imaging forum.
By the way, the easiest way to measure PE is to offset the azimuth axis and let the star drift in Declination. Then you can see the wiggles on a time exposure and measure the error in pixels. Are you using PemPro by any chance to measure the PE?
Rolando
