How long does an ad run?
Started by tjmorrow, 03/24/2010 01:13PM
Posted 03/24/2010 01:13PM Opening Post
I just noticed that my ad is no longer posted. Do they get dropped after a number of days? Can I re list the ad?
Posted 03/24/2010 02:20PM #1
Your ad most likely is still there. The default view is for 10 days I believe. You can change that, up to 90 days or you can search for older ads. Or, you can go to "my classifieds under your profile.
Posted 03/24/2010 03:35PM #2
Your ad is still there. It shows up, based on my settings, on the 7th page of the ads in that section.
Posted 03/24/2010 07:24PM #3
Ads dont go anywhere unless you delete them or they dont fall within the TOS and AM deletes them.....When you are listing ads it only goes back a few days.....once your ad is older you have to define how far back you want to look when purusing the ads.....The system will let you define upto 90 days (the default is less than 30.....after its 90 days old then the only way to see it is via the search option.
20" MidnighTelescopes f/5
8" f/16 Muffoletto Achro
Meade 6" AR6 f/8.0 Achro
Celestron C11
Parallax PI250 10" F/5 Newt
Vixen FL102S,NA140SS,R200SS
Monroe GA
