VDB 142 Elephant Trunk HOO
Unitron 4" Equatorial
Started by pbrayton, 07/22/2011 10:27PM
Posted 07/22/2011 10:27PM Opening Post
Bought the ota's separate from the mount and now she's all together! I do have one problem though, the latitude adjustment nut/bolt assembly is not long enough for my latitude...it only goes down to 45 degrees and I'm at 39 degrees. Any ideas?
pbrayton's attachment for post 53796
Posted 07/22/2011 10:46PM #1
Try lowering the front leg of the tripod a bit. If I am not mistaken, it need not be perfectly level to polar align.
Or, maybe with a lot of effort, the bolt could be exchanged with a longer one, but I suspect there would be no room to do that.
Any chance you could provide a close-up shot for us to examine?
Posted 08/23/2011 01:34AM #2
Hi Pete,
I will pile on with one more suggestion. I would highly recommend:
Ashley Stevens
Precise Parts
He is an artist with a lathe. He has made several things for me. I have seen a big scope (23 inch refractor) that was modified with what you might call a reverse wedge. This wedge imparted the latitude difference in the negative - so, in your case a downard pitch of 6 degrees. This is the large Clark Refractor at Roper Mountain, that was moved from Princeton, NJ to Greenville, SC.
respectfully,
steve
