Philip Imbrogno
Elephant Trunk Nebula
10X70 vs 10X50 binos
Started by paulsky, 11/10/2011 06:30PM
Posted 11/10/2011 06:30PM Opening Post
Hello,
I am looking for a binoculars for wide angle astronomical observation, the candidates are this two model 10X50 or 10X70, you have observing with this models, for nebulas and star clusters..Milky way, Pros and Cons?
thanks
Best
Paco
Posted 11/10/2011 08:40PM #1
Paulo,
The main difference between the two types of binoculars you mentioned will be the exit pupil size. The 10x50 will have an exit pupil diameter of 5mm and the 10x70 will have a 7mm exit pupil. If you are 20 years old, you can probably make use of the larger exit pupil but if you're over 50, the larger exit pupil will likely be of no advantage and you will be wasting your money on the larger objective lenses. You would likely be better off spending that money on a better quality 10x50 binocular.
My personal preference are high quality 7x50 (Porro prism) binoculars, not for the 7mm exit pupil but for the wider field of view they provide. (At 61, my pupils no longer fully open.) The lower magnification also makes it easier to hand-hold the binocular steady while scanning the sky, when I'm not using a tripod.
Whichever binocular you buy, immediately check them for proper collimation. Once the binocular is focused, both eyes should immediately bring both images together to form one image of an object (star, moon, etc.) If it takes a couple seconds for your eyes to adjust and bring the images together, the binocular is out of collimation and should be rejected. Usually only the best quality binoculars are in perfect collimation and with careful use, will stay that way.
Posted 11/10/2011 09:46PM | Edited 11/10/2011 09:50PM #2
10 x 50 will give you a wider FOV. Orion UltraViews, for example, have a 6.5 degree FOV.
For binocular astronomical observation, magnification is more important than aperture (opposite the adage for telescopes). For that reason, you will not get much gain in seeing the objects you mentioned with larger objectives. What little you gain will be lost in field of view and weight.
Of the two choices presented, I'd go for the 10x50's.
Posted 11/10/2011 10:06PM #3
Paulo martin said:
Hello,
thanks
Best
Paco
Paulo:
Can you be more specific, do you have any binos in mind?
Posted 11/10/2011 11:07PM #4
Paulo: I've owned many different binoculars over the years. To answer your question, I assume you are planning to mount these so you can have a nice, steady view. IMHO, it's tough to hand hold a binoc steady enough to detailed observing at 10X. For hand held sweeping of the Milky Way, I prefer a 7X50 or 9X60. I also assume that you've personally looked through some 10X70 and 10X50 binocs so you have an idea about how they perform. If not, head out to a star party and see if you can test some.
If you have relatively dark skies, the for Milky Way sweeping, aperture is important. I would choose the largest aperture I could afford. However, another poster is correct regarding exit pupil size. Also, if you observe from heavily light-polluted areas, you might do better with a smaller aperture/smaller exit pupil as the constrast will be better. If neither of those applies to you, then I'd recommend the 10X70 binocs.
I agree with the other poster who advised purchasing a high-quality binocular. Get the best ones you can afford. Good luck!
- Chuck
