Jay Messeroff
Lunar & Solar Transits
Celestron 15x70 vs Orion 15x70
Started by ref68, 07/17/2011 06:02AM
Posted 07/17/2011 06:02AM Opening Post
what do you know?
Refet.
Posted 07/17/2011 08:18PM #1
refet dehari said:
what do you know?
Refet.
Refet:
When it comes to binoculars, you pretty much get what you pay for. Orion sells at least 3 different 15x70s, the $90 model, the $225 Giant Views and the $370 Resolux's.
The $90 model is most likely very similar to the SkyMasters, that is mechanically questionable, collimation uncertain and while the lens are 70mm, due to restrictions in the optical path, the effective aperture is only about 63mm.
The $225 Giants used to be made in Japan. They may represent a significant step up, mechanically robust, good quality optics, operating at full aperture.
The $370 Resolux are good enough that Roland Christen was confident enough in their quality that he was willing to sell very similar binoculars under the Astro-Physics name. The A-P web page still lists them but I don't know if they are available.
http://www.astro-physics.com/index.htm?products/binoculars/70mm/pb105x70
A pair of 15 x 70 binoculars is a pretty complicated bit of optics... two 70mm achromatic refractors two sets of prisms to erect the image, two eyepieces plus the mechanical components necessary to link the focusing and the refractors together in a solid mechanical piece.
It is pretty clear to me that doing this for under $100 requires taking a lot of short cuts... For example, these are fast refractors, usually about F/4. Like that F/4 Newtonian you mention in another post, edge correction is not going to be that great... An eyepiece that is sharp to the edge at F/4, it's not so cheap...
If you want a pair of 15x63's and are willing to collimate them when needed (including upon arrival), I have been assured that the 15 x 70 Skymasters are actually a reasonable choice.
