Well my new "Saturn Prismatic Space Binoculars Model NBA-71" arrived yesterday afternoon. The above title is what is on the bino's and I thought it cute. I have only had time to give them a visual and set them on my Universal Astronomics Unistar mount (see photo) those of you who are sharp eyed please note that they have not been mounted for balance yet. The first impression is that these are some strange looking binoculars. Very long and narrow looking but nice. The measurements are 21.6in.x8.6in.x5.5in with the dew caps in. They weigh 8.6lbs. Using the flashlight down the tube inspection all coating appeared to be even and all surfaces well coated as best as I could determine. Collimation at this point looks good. The insides of the tubes were evenly and adequately baffled, clean and dark with no minor derbies or uneven flocking. The base of the scope has four holes drilled and tapped for the standard 1/4 by 20 bolts. It also has a hole drilled for and threaded for a 3/8 bolt which is centered on the base plate of the bino's. This gives a fairly good selection for mounting options. I was a little concerned as Miyauchi makes its own proprietary alt-az mount and stand for these bino's so I was happy to see that they still left mounting flexibility. The small finder contrary to what others have said about the one on the Miyauchi 20x77 I think is excellent. Particularly the recticle set-up inside along with the smooth focusing. Although small the finder feels substantial. The mount for it has the front adjustment screws and an O-ring something like what Celestron used to use on their finder scopes although this one is more internal holds the rear steady. Will have to see how well it holds alignment when removed from binoculars. I must say that the general impression one gets when looking the bino's over is one of quality. Very nice fit and finish. The dew caps at the end of the objectives slide firmly in and out with no sign of slop or looseness. The extra eyepieces that I ordered (40x) have a nice feature that I am told some of the other Miyauchi bino's did not have. When you change eyepieces they now just don't drop in and set lose but after drooping them in you turn then clockwise and they lock in. This is really part of the binoculars as well since the 22x eyepieces do also. As I am all too aware the real test of these binoculars is yet to come. I am very curious to see how much if any the F/8 aspect works to reduce chromatic aberration on these achromatic binoculars. Also curious about any increased resolution on objects. I would like to wish for good weather but I learned a long time ago that"If you want to make God laugh, just tell him your plans!" Hope this little review was not a waste of time to read. I am a relative novice compared to most of you folks.
R/S,
Dan
R/S,
Dan
Danny Halstead
Moderator APM Forum
