Denkmeier and collimation
Started by kagge, 04/07/2007 11:07PM
Posted 04/07/2007 11:07PM Opening Post
On the Denkmeier site it mentions that collimation should be done with the binoviewer in place. If I want to view using a 2" eyepiece, is collimation needed each time I switch between the two?
Thanks
Dave
Posted 04/07/2007 11:31PM #1
Hi Dave,
I think the binoviewer will result in a higher magnification and need a tighter collimation. The weight of the binoviewer may also flex the focuser slightly, so collimation with the binoviewer in place may compensate for that slightly.
Binoviewers magnify any type of optical problem. So a good collimation is good for them.
I do not believe that switching back to a 2" eyepiece will shift the collimation enough for you to notice.
Don
