A little fuzzy on which system would be required for the Televue 76 refractor. Is the 1.25 inch vs 2 inch a light/field of view issue or a compatability issue? What do I need to make this puppy work, believe I have come down with the fever! Many thanks, colin
Denkmeir and Tv 76
Started by stubby, 07/30/2003 02:49PM
Posted 07/30/2003 02:49PM
Opening Post
Posted 07/30/2003 05:52PM
#2
Colin,
The advise to talk to Russ is right. A very good guy, very helpful. I just got a Denk Deep Sky and have used it just a bit in my TV85.
Regarding your question-if I understand it correctly-it's a "light/fov issue". You can use the 1.25 or 2" OCS. For the 76, you'll need a part T and part S with the 1.25" setup (along with the part O).
If you go 2", you'll need a part SR along with the part O. Russ will set you straight on it. I was out last night with it and was pleased with it, need to get it to a darker sky site so I can see what this li'l puppy can really do....
Good luck,
-Curtis
Good luck,
-Curtis
Funding Member
Sponsors
- RemoteSkies.net
- OMI OPTICS USA LLC
- BBLABS LLC
- astronomy-shoppe
- SellTelescopes.com
- CarbonScopeTubes LLC
- Anacortes Telescope
- BW
- Matsumoto Company
- Vernonscope
- kwtelescope
- Astromart Customer Service
- Desert Sky Astro Products
- Waite Research
- APM-Telescopes
- FocusKnobs
- AstroMart LLC
View all sponsors
