Ghost of Cassiopeia
Eye-pieces for Denkmeier Binoviewers
Started by Hans Tucker, 12/05/2006 09:16AM
Posted 12/05/2006 09:16AM Opening Post
Well I took the gamble and after a bit of research settled for purchasing a Denk II Refractor package now I am presented with a delema of chosing suitable eyepieces. Any suggestions??? I did note that Denkmeier have their own range of eyepieces available, the D14mm & D21. Odd that they only offer these two focal lengths. What are you fellow Denkmeier owners using?
Cheers,
Hans
Posted 12/05/2006 01:33PM #1
Hi Hans,
I use 24mm TV Panoptics and the Denk 21mm eyepieces. With a two arm Denk Powerswitch, one doesn't need much more. That allows for 3 different magnifications with one pair of eyepieces. I also have a pair of 15mm TV Panoptics, but they don't get much use since I purchased the Denk eyepieces! When I started using the 24mm Pans, I thought I had the ultimate eyepiece for the binos. But when I attended NEAF and had a chance to use the Denk 21mm eyepieces I was amazed. They are a bit pricey but worth every penny!
Posted 12/05/2006 01:47PM #2
Hans,
I use a pair of the Denk21s with my DenkII binoviewer in a C11 scope. They work great and the system as a whole gives very sharp and contrasty views. The Denk21s' have a large AFOV of 65 deg. good eye relief. They also have a large field lens which I like. They have winged eyeguards instead of the standard eyecups. since I wear glasses most of the time, I have to fold them down. A unique feature is that the eyeguard itself rotates wrt the EP body. The Denk21s also come with a nicely machined metal housing known as the "vault". A bit of overkill in my opinion (I have actually set them aside and use plastic bolt cases) but very nicely made. The only potential "drawback" is that the Denk21 body is sort of fat and is not tapered. If you have a big "schnozola" combined with close eye spacing (like me!) it can feel a little cramped when you look thru them. My nose is typically pushing on the EP body. But you get used to it pretty quick.
John
Posted 12/05/2006 01:55PM #3
I've used both the D21s an D14s and the are really great EPs. When I switched from a CAT to a refractor I was having problems with weight issues (these are big EPs!). I now use a set of Pan 19s and the views are increadable!
Brian G
Posted 12/05/2006 02:19PM #4
Hi Hans,
I have the D21s, 19mm Panoptics, and 18mm Radians. I think the 18mm Radians get the most use. You also might want to look at the 24mm Siebert Ultras. They are a great EP for less than half the price of the others I mentioned and they give you more room for your nose. :>)
Don Durbin
Posted 12/05/2006 02:25PM #5
Hello Hans
I have the Denk II with PowerSwitch and it works great. I've been using the Nagler 13T6's and 5T6's. I already had a set of Naglers so it was easier to just match up new one to make a pair then buying new sets. Naglers probably vignet but the views are excellent with the 13's and the 5's are ok in the lower powers of the PS. The higher setting with the 5, I think the exit pupil get too small for me and turns dark and muddeled. I did have the chance to use the D21's and much prefered the views with the Naglers. The samples that Russ let me borrow were no where near as sharp as the Naglers. I do not know if it was this sample or if the Naglers were that much better?
Just my $.02
Buck
Posted 12/05/2006 04:08PM #6
I use 30mm Celestron Ultimas and 19mm Panoptics but I wouldn't mind having a pair of the 21mm Denkmeiers.
Dave Mitsky
Posted 12/07/2006 10:08AM #7
Thanks all,
I took in the information on each post and really appreciate the recommendations. One variable element I did take in was individual preference but the purpose of the original post was to look for a common element in what users selected, which I did pick out.
