2" visual back on an Astele LOMO 95?
Started by klipy, 04/28/2004 10:48PM
Posted 04/28/2004 10:48PM Opening Post
Can anyone tell me if an Astele-LOMO 95 will accept a 2" visual back?
Posted 04/29/2004 07:05PM #1
The Astele 95 utilizes the standard SCT rear port coupling, so the short answer is YES -- a 2-inch visual back (or diagonal) CAN be mounted to the scope.
What I'm not certain about is the scope's inherent moving-primary focus range -- whether or not a 2-inch set up will allow for visual focus at infinity. Experienced owners should have some insight, here. Perhaps a test may be performed: try a 2-inch SCT diagonal, or install a 2-inch extension between standard diagonal and eyepiece & see if scope can reach infinity focus (&/or focus *beyond* that point). The extension should approximate the "length" of a 2-inch set-up.
Assuming 2-inch focus *can* be reached, there are yet two other points to keep in mind:
1. Such a set up *will* yield a vignetted image plane -- *significantly* vignetted (image will be dimmer off axis).
2. Such a set up *may* result in aperture stop-down (primary baffle may intrude upon light cone & reduce the scope's working aperture). Both the design/dimensions of the primary baffle *and* the inherent moving/focus range of the primary will determine whether or not stop-down will occur.
Enough babble from me. Let's hope some owners can offer more insight and experience.
Best wishes.
-Dan
