49mm Filter and TV Diagonal Questions
Started by toml, 09/16/2003 05:48PM
Posted 09/16/2003 05:48PM Opening Post
Hi.
Is a "49mm filter" one and the same as a 2" filter? or is it just a camera accessory?
I have a 2" TV everbright diagonal, but all 1.25" EPs (for now) connected with the adapter.
I don't enjoy unscrewing and screwing a filter between EPs all the time, so it would be nice to screw it on to the MCT (Intes MK67) end of the diagonal (the tv diagonal looks like it's threaded for a 2" filter I think on that end).
So, is that right? Can I get something being sold as a "49 mm" filter and screw it on to the MCT end of the TV diagonal, and then just swap out EPs at will to change magnification without fussing with the filter each time?
Tom.
PS. I am planning a mid-sized dob right now, and will eventually make some kind of filter slide for the upper cage, so probably 2" filters would be better for that too in order to avoid vignetting right?
Posted 09/16/2003 05:55PM #1
Tom,
A 49mm filter is not the same as a 2" filter. A 2" filter is actuially 48mm and although close, a 49mm filter will not fit a 2" eyepiece or diagonal threads.
Posted 09/16/2003 05:55PM #2
Moonlight makes a neat attachment for their focusers to hold and swap filters on the fly.
Floyd
