55mm Plossl focus problem
Started by genex, 11/07/2003 05:32AM
Posted 11/07/2003 05:32AM Opening Post
I have a Genesis-SDF and my TeleVue 55mm Plossl will not quite reach focus with the draw tube at maximum extension. Is this normal? Thanks, Gene
Posted 11/07/2003 08:19AM #1
I've heard this happens more but relax, if you can't extend enough for focus to occur you can attach an extension tube. You'd have a bigger problem if you couldn't get enough in-focus. Do you have a diagonal in place?
Nico
Posted 11/07/2003 08:05PM #2
TeleVue makes a barrel extender for the 55 Plossl.
Product number EBX-2120 I think. Its basically a
2" OD tube with 48mm threads on one end; something
like 1.5" long. It will have the effect of moving
the eyepiece higher in the diagonal, thus allowing
it to reach focus more easily. Something like $20.
Posted 11/08/2003 10:27PM #3
I am wondering why you want to use an eyepiece with a 55mm focal length with such a fast telescope? Assuming the focal ratio of the Genesis is f/5, the exit pupil diameter will be about 11mm, which means you will lose almost half the light entering the telescope, which isn't very good for deep sky.
Is there some advantage over using a 35 mm TeleVue Panoptic, which will have a 7mm exit pupil diameter, and almost as wide a field of view?
Greg
