Ralph Ford
M31 with Redcat 51
.965" eyepieces
Started by [email protected], 08/15/2002 12:24PM
Posted 08/15/2002 12:24PM Opening Post
There's a trickle of .965" eyepieces on Astromart and Takahashi markets a few new eyepieces in this barrel size. Are there .965" optics which are considered good enough that we should be searching for them and buying adapters?
Bob Polcyn
Posted 08/15/2002 02:48PM #1
Hi Bob.
Zeiss, Pentax, & Takahashi are most popular among recent (or current, in Tak's case) premium .96 eyepieces. Other (rarer) premium 96ers include JSO, Goto, Nikon, Kowa. Any good example from one of these brands is worth full consideration, in my opinion. Most will have the "orthoscopic" label (whether traditional Abbe or not), but you'll find Kellners & other designs, too. The Pentax XPs, for example, are designed for eyepiece-projection astrophotography, but many folks swear by the 3.8mm XP as a great planetary eyepiece.
Actually, my early '90s Celestron 18mm Kellner is excellent, too.
I'd have absolutely no qualms or hesitation about buying a good example of a .96 orthoscopic or Kellner from any of the above brands, if the price is right.
A bit of trivia, as an aside: the Takahashi 5mm & 7.5mm LE eyepieces utilize negative/amplifying elements in a sub-diameter assembly *within* the 1.25-inch barrel. This assembly is, itself, housed in a .96-inch barrel. If one were so inclined, they could unscrew the 1.25-inch barrel and use either of these LEs in a .96 diagonal or focuser. I've not done this, nor do I suggest it. The sub-diameter barrel is black-anodized alloy and, I'm sure, more prone to scratching/gouging. Removing the 1.25-inch barrel also exposes threads which would be prone to damage, as well.
Best wishes.
-Dan
Posted 08/19/2002 04:29PM #2
I have Tak .965" eyepieces in 2.8, 4, 5, 7, and 18mm focal lengths. They are excellent for planets, but have a narrow field of view, and in the 2.8 and 5mm, very short eye relief. You should definitely try before you buy, or if you see any for sale on Astromart, see if you can arrange to return them if you don't like them (some amateur astronomers are very nice this way). I like mine so much I'm going to complete the set.
One more thing: the Taks are tiny; for low power I have a Pentax 28mm which is about the size and weight of a hand grenade (I think; I've never actually held a live hand grenade). If I'm not careful, my 80mm refractor can go like a see-saw when I switch eps.
