Alternative to Astronomy Ladder ???
Started by AstroKwang2, 11/17/2005 07:17PM
Posted 11/17/2005 07:17PM | Edited 11/17/2005 07:17PM Opening Post
Does anyone make a viewing seat/chair that places the viewer
at 8-10 feet? Or has anyone made such a 'high chair'?
I'm contemplating a longer focus 16-18" dob. Though I don't
mind using a ladder, I would like to be able to sit
for 5-10 minutes at a time to enjoy the views. In theory,
I don't mind coming down and moving such a chair if I can
comfortably sit for awhile.
This question might belong in the Dobsonians board, but maybe
someone might have a lead here...
Posted 11/17/2005 10:30PM #1
Is there a great advantage to a longer-focus Dob? With, for example, a Starstructure 18" F/4.3, the zenith eyepiece height is only 77". A chair for that height might still be a custom item, but it would seem to be safer than one 8' high.
Posted 11/18/2005 01:56PM #2
Kwang,
This may be what your looking for. Its called a tripod deer stand. It seems to be light and portable.
Hope this helps,
Jay
http://www.backcountryjournal.com/podz.htm
Posted 11/18/2005 06:36PM #3
Curious if you have ever owned a "ladder" scope??
jon
Posted 11/18/2005 07:25PM #4
Hi Kwang,
You know, you are entering into one of the biggest controversies in Astronomy! wink
To ladder or not to ladder, that is the question?
I have had to climb a few ladders and for me the taller the ladder the less that I wanted to climb it. Even a short one of 3 steps would get old quickly. I sold a wonderful 15" to buy the 14.5" Starmaster, just to get away from a 3 step ladder. It just was a pain to always have to climb down for an EP or to move the scope to a new position. I found myself wanting to use a part of the sky that I could stand on the ground instead of the higher elevations.
When I got the 14.5" and was able to stand flat footed in all positions and use a chair to allow me to sit and relax for minutes at a time, then it became a more pleasant experience for me.
I still love to climb a ladder now and then for the view through a large scope. It is always amazing. But at the end of the night, I am still happy to be standing or sitting at my scope.
Posted 11/27/2005 02:55PM #5
Kwang, it won't quite get to your 8 foot minimum height, but Jim Fly's "Cat's Perch Pro" chair http://www.catseyecollimation.com/cperch1.html has a maximum height of 46.2", and has an built-in adjustable footrest you can use to climb onto the chair when it is set in these high seating positions. Jim has stopped selling the finished chairs and hardware kits, though, so you'd have to buy the plans and build it yourself.
Depending on how tall you are, this can get you close to your minimum height requirement-- I can see level into a eyepiece 84" (7 ft) off the ground using my chair, and I find it relatively easy to get onto--though a bit tougher to jump down from, especially when bellied up to a scope. It might be a viable option, though, if you opt to go for a 16" scope of ~f/5.5 or thereabouts.
For what it's worth, I went through the same experience you're contemplating, and ended up owning a 20" f/6.7 for a couple of years. I found that the additional coma-free field of view did not make up for the hassles of dealing with the ladder. (There also wasn't enough extra light grasp beyond my 16" to justify it either, but that's a separate issue.) Your mileage may vary.
Good luck!
Jim
