M33 in Triangulum
Autoguiding scope choice: 66mm or 80mm
Started by Ralph Skogen, 07/22/2012 12:48AM
Posted 07/22/2012 12:48AM Opening Post
Hello everyone,
I am getting ready to try my hand at some imaging. I'll be using a Losmandy G11 with scopes from 500mm fl to 2000mm. I would like to use one of the small scopes I already have for the autoguiding. Should I use a 66mm w/400mm fl. or an 80mm w/550mm fl.? Is the extra 14mm of aperture and 150mm of focal length, worth the extra size/weight? Which would you use? Or am I off base and should use something else?!
Thanks in advance,
Ralph
Posted 07/22/2012 03:40AM | Edited 07/22/2012 01:24PM #1
I use an 80mm f6.25 as a guide scope with great results with my AT8RC on a CGE mount. The 80mm has a little more light grasp and the longer 500mm FL gives better guiding with longer FL scopes.
ccdfreak's attachment for post 144858
John
CCD-Freak
WD5IKX
Posted 07/23/2012 11:16PM #2
Either will work fine but use which ever one has the most solid focuser. That will help minimize one of the many forms of flexure you'll most likely run in to with a separate guide scope.
Robert
