Bad idea: 360 degree tripod rotation?
Started by gnowell, 11/05/2009 02:59AM
Posted 11/05/2009 02:59AM | Edited 11/05/2009 03:17AM Opening Post
When I was working with Berlebach on their eventual Losmandy compatible tripod designs, the prototype they send me had the counterweight positioned BETWEEN two legs, not OVER one leg.
I found this to be very unstable: it doesn't take much of a push to "go over" when you have the center of gravity between two legs.
I noticed this because I see a vendor here advertising the desirability of 360 degree adapter rotation for setup. This is not unique to this person: I know of a few other cases. It seems to me that it is not a good idea at all, and that AP was right to put a stop in the amount of adjustment they give you. If you are "allowed" by the mount to position exactly between two legs with the counterweights, you are at risk for tip over.
I hope the picture here makes this clear. The risk may be minimal with a light mount but if I were setting up and had radically misplaced true N I would rather lift the entire tripod and move it to get closer rather than observe all night with the counterweight and telescope mass perched overhanging the two extended legs. I discovered this truth with the prototype Berlebach and the C14/G11.
Long story short: I always thought it would be nice to have infinite or 360 degree adjustment but when I came face to face with reality I discovered that it wasn't a real good idea. I have another pic of the Berlebach prototype which did not get marketed that way.
I have also seen some folks set up counterweights between-the-tripod-legs, and I consider this a no-no. Regrettably the lower your latitude the greater your temptation to set up this way, and I suspect, the worse the results. In a low latitude with the counterweight over the tripod leg the shaft might actually hit the leg. Put it this way. In a low latitude if I were observing with the counterwegiht *between* two legs I would stake down the rear leg as a failsafe. I've been in too many situations where the wind suddenly kicked up. A tripod is impossible to knock over when force is applied from between two legs against an extended leg. It is EASY to knock over when force is applied from behind one leg toward the empty space between the two other legs.
regards
Greg N
gnowell's attachment for post 48921
Posted 11/05/2009 03:06AM #1
Discovering the truth with a C14 must have been ugly...
Posted 11/05/2009 03:08AM | Edited 11/05/2009 03:14AM #2
This next picture demonstrates the same problem more vividly.
Obviously, when you load a GEM you put the counterweights on before you put the OTA on. You do this so the whole thing doesn't immediately capsize. You can see from the pic that this mount is in an unstable position and it's really the fact that the sharp points are jammed into the grass that this thing is holding.
NOW, the kicker is, when you slide that C14 in from the back, you are PUSHING in the weakest direction: from behind one leg into the middle of the other two!
Bad idea! Fortunately my friend Pete was there to catch the whole thing as it started to tip over....
I'm not a genius. I learn from experience.
Berlebach subsequently developed a SUPERB Losmandy style adapter so this version, which required that the mount be placed in the wrong direction, never got sold. These beautiful tripods are now sold by Teton telescopes.
In any case most tripods give you the option of setting up backwards, and that's probably a bad thing. What worries me about 360 degree rotational options is that they invite GEM owners to forget that the stability of the mount changes radically with the placement of the counterweights vis-a-vis the tripod/pier legs.
I'd like to say that I'm a smart guy and I would REMEMBER not to use my 360 degree adjustment to put the weights between the tripod legs but I worry about that as a point in fact. I've done some incredibly dumb things during setup, because I was in a hurry and got sloppy.
Greg N
gnowell's attachment for post 133707
Posted 11/06/2009 10:32PM | Edited 11/06/2009 11:03PM #3
regards
Greg N
I have only seen this as a problem with my lightweight set-ups, and all but one of my tripods/piers has a fully rotating azimuth.
Rick Keppler's attachment for post 133771
