Philip Imbrogno
bulk "pluck" foam
Started by csa/montana, 03/16/2006 07:38PM
Posted 03/16/2006 07:38PM Opening Post
Anyone have a source that sells "pluck" foam in sheets? I have an unusual case that I need to replace the pluck foam & can't find the insert needed. Thanks!
Posted 03/16/2006 08:00PM #1
Buy regular foam and cut the foam to fit the items, it works better and last longer.
fblue's attachment for post 101937
Posted 03/16/2006 09:21PM #2
B&H Photo Video probably has replacement foam for doscocil cases.
But other than the convenience of setting it up, I think you will be happier in the long run with the regular foam you have to cut yourself.
Posted 03/17/2006 07:34PM #3
http://www.efoamstore.com/
Can even order foam to be "firm" for easy cutting....
Posted 03/17/2006 08:48PM #4
go to www.foamrubber.com The Foam Discount Center. I suggest that you stay with Ester Foam it doesn't outgass. These folks are very helpful and will pre-cut sheets to your specs.
