Cooling fans? Heaters? Help!
Started by astroboy314, 11/17/2004 04:20AM
Posted 11/17/2004 04:20AM Opening Post
Hello all! I am the proud owner of a new (well, used) Starmaster 14.5" (and I don't actually have it yet... but soon). I have a question about the use of cooling fans or heaters.
Keep in mind here that I'll have to store the scope inside and will be transporting out to my observing site. Also, I'm from Canada and in the summer I'll be observing in rapily-cooling evenings of 10C, and in the winter I'll have observing temps of -25C.
I have been told I should install a couple cooling fans for the primary, but is this more a necessity for observers in desert-like climates? Would a cooling fan do anything in cold winter temperatures? If I install fans, should they be beneath the primary and pull air in or blow it out, should they blow across the mirror or pull air out from the mirror surface? Or a combination of all of these? I've also heard that Dob primaries aren't very succeptable to dew, so I'm curious if a heating pad for the primary would help at all. Would having a heater on the primary help in reducing cool-down time or would it just cause more currents above the mirror? Can the primary frost up without a heater? How succeptable is the secondary to dew?
Wow... I didn't realize I had so many questions until I started to ramble! Any advice on any of the above topics would be greatly appreciated!
Dave
Posted 11/17/2004 05:48AM #1
Yes. It will help the primary mirror keep
up with rapidly falling external temperature.
I think this is subject of some debate.
Definitly circulating air in / out below
mirror will help. Whether blowing in
or out you will get different opinions.
Across mirror may help break up boundary
layer, but can also creat turbulence in
optical path. Try it and see. Some
combination is probably best.
> Would having a heater on the primary ...
In general, the primary will be the last
thing to dew-up. But once it does reach
ambient temp, it can and will dew. A heater
will not speed cool-down. But it might
help reduce dew. I have heaters on some
of my primaries -- I put them on very low
power if dew is very bad, but this
does not happen often.
Very. Get one of these AstroSystems heaters
that keeps secondary 1 degree C above ambient
temp, and use it all the time.
