Philip Imbrogno
Elephant Trunk Nebula
Coulter Odyssey scopes
Started by fblue, 11/24/2004 07:25AM
Posted 11/24/2004 07:25AM Opening Post
I am thinking about buying one of these as a grab and go scope, a 10" that is for sale here. I am not really that familiar with them. Anyone here that can enlighten me?
Floyd
Posted 11/24/2004 09:27AM #1
If it is in it's original configuration, then it will be pretty heavy for a ten inch dob. Very stable, but heavy. Plate glass mirror in a closed cell. So it can take a while to cool to ambient temp. Original equipment Coulter's are functional, but by today's standards they are very much a project scope: lots of improvements possible/desirable.
However, if the scope already has upgrades (often in bearing surfaces, active cooling, focuser etc) then it will perform on par with any 10" f/4.5 newt.
Posted 11/24/2004 03:34PM #2
Hi Floyd,
I owned a Coulter several years ago and still have a nostalgic view of them. You've had great advice about them being a hobby scope. If you find one in pristine condition, I would keep it as an heirloom, but if it is not absolutely pristine, check out the mirror. Some of the mirrors were stinkers, but some were superb. I have a friend with a 13" and its mirror is excellent.
If you get a great price, then you might consider buiding or buying a scope to go around it. There are a lot of fine truss dobs out there based on Coulter mirrors.
BTW--If you have a totally utilitarian view on this, buy a 10" DSH. They are prettier lighter, possibly cheaper (on sale) and have better components.
Best wishes,
Randy
Randy Roy
Posted 11/24/2004 05:51PM #3
Hi Floyd,
I have a later model original Coulter red tube 10". It's heavy and hard to move. Not all that stable either, as the bearing surfaces are not teflon. The mirror is very thin, and glued to the cell, which for a 10" mirror is not the best solution. The focuser is somekind of pipe fixture, which works, but begs to be upgraded. The optics on mine are passable, but I also have a 13" mirror from Coulter that is >very< good. The earlier blue tube models are supposed to have the best mirrors, as they were close to full thickness. I got my scope very cheap, so I was not as concerned about all those things.
Bottom line, check it out in person, and if things look OK and you don't mind the weight, you may be OK. But as others have said, these are really "project" scopes, so if you like to build and modify things, this could be your scope !! grin
Oh, as others have mentioned there is also a "new" Coulter which will probably be a completely different configuration, can't comment about those.
Let us know what you find out !
David Simons
David Simons
