Iris Nebula
Do I really need to clean my mirror, please help
Started by ricardoamador, 01/22/2004 06:24AM
Posted 01/22/2004 06:24AM Opening Post
Hello all, I opened my schimidt newtonian around 2 months ago, because I thought it moved durind a travel I did to a star party. I noticed some dots so I cleaned it. well got it worse, now there appears to be a fogged area, that looks just like the one in the drawing, I dont know if it is oil residue from my hands or powder of the glove I used. I notice no difference in my seeings, and I really dont want to clean it again, last time I made a long but thin scratch on the coatings of the mirror. Would this fogged area affect my view, should I clean it? or should I leave as it is, could this make my telescope gather less light?
Thanks a lot.
Ricardo R. Amador
ricardoamador's attachment for post 12482
Posted 01/22/2004 07:03AM #1
Ricardo,
It is very difficult to tell what happened by drawings alone.
What you discribed sounds like residue from the cleaning solution. It is hard to clean just a part of a mirror without leaving some film on the mirror. Each time you clean one section you seem to streak the section next to where you clean. That is why I always remove my mirror and clean it completely with a pre-rinse of water to remove any particles that might scratch the surface of the coatings before I use soap and water to clean it thoroughly. Followed with a good rinse with distilled water and then dried by tilting it and using a hair drier on the cold setting to blow off as much of the water droplets as possible before dabbing off the ones that won't blow off with a corner of a soft tissue like Klennex.
You might just want to leave it alone until it gets very dirty and the clean it. It is difficult to tell someone what to do about something like this because I don't know how well you would fare in doing a mirror cleaning.
I would suggest that you do a bit of research before you attempt to clean any optics again. This is something that can turn into a disaster if done improperly.
Floyd
Posted 01/22/2004 01:56PM #2
Hi Ricardo,
Well opinions are like, uhmm, noses, everybody's got one. Here's mine...
I'd clean it but definitly take heed of Floyd's advice about distilled water, and yes, begin by allowing running water to rinse off any looses particles. And I would add that while cleaning the mirror, forget the gloves. If treated, they'll introduce chemicals onto the mirror. If not, they can still introduce lint.
Just wash your hands throroughly first. Use cotton balls and VERY mild dish soap to do the cleaning. Apply the dilluted soap to the mirror and swirl it around GENTLY under running water with a few cotton balls in hand. Don't "turn" the cotton balls, as any finger oils will be on the side you hold. IN other words, let nothing touch the mirror that has touched your hands. Grab new cotton balls instead. Repeat this so that the residue from the film on your mirror gets washed off as well.
When done, rinse and dry as Floyd suggested, but don't use Kleenex! It will deposit tiny flakes of lint back onto the mirror. Use an old, clean, well-used towel that has had all the lint washed out over many washings. And BARELY dab the surface. I can usually dab up the water droplets without actually contacting the mirror surface.
I would not want an unknown substance on my mirrors. If you're not sure what it is, it could be something that could attack the coatings over time if left there.
Once you're happy with your cleaning job, remember the old saying, "A dirty mirror is better than a poorly cleaned one." The little dust specks that take up residence on optical surfaces don't affect performance very much at all, certainly it would have to be really dirty to degrade your images noticeably.
Good luck,
Bob
