ETX
Started by n.i.x, 03/31/2005 05:21PM
Posted 03/31/2005 05:21PM Opening Post
Hi, I'm looking for some good info/links on the 'motor unit fault' problem with the ETX. Thanks.
Posted 03/31/2005 09:15PM | Edited 03/31/2005 09:16PM #1
Nico,
You can also try:
http://www.arksky.org/index.htm
Take a look under services. The contact on this site has helped me with a few quesitons.
A few things to consider:
Use some electrical cleaner on the Autostar cable contacts. I have had to do this.
Reset the Autostar and retrain the drives, then make sure all your settings for location and time are correct.
Make sure you have enough power. Are the batteries fresh, or is the power supply cable in good shape?
Good luck,
Paul
