ETX90RA mod
Started by Blindeye, 09/01/2004 04:45PM
Posted 09/01/2004 04:45PM Opening Post
Ok, another in my series of "I'm new and don't know any better" postings...
By now it's fairly obviously that I bought my 1st serious scope, a used ETX90RA. Rolando Chavez has provided expert adjustments and cleaning on the old girl and I anticipate it's speedy return. Meanwhile, I see many ETX 60 and 70 refractor, "Go-to's" advertised for very low prices. Here's my question: Could I mount my OTA 90 onto the yoke of a GOTO ETX 70? It appears from photos I've seen that the method of mounting is similar. However, I cannot ascertain the width of the yoke. Am I way off base on this one or has someone else made similar attempts? I keep on coming back here because this forum is by far, the best I've found online.
wink
Don
Posted 09/01/2004 05:44PM #1
Don
The ETX90 OTA will not fit on the ETX 60 or 70 fork arms. I have a Nexstar 114 mount with an adaptor plate that works great for a go-to mount for a variety of OTA's for optical use only.
I also have a couple LX200 mounts I have adapted with a saddle bracket for mounting a variety of different OTA's. These work well even for medium focal length photography.
Hope this info helps.
Posted 09/01/2004 06:32PM | Edited 09/01/2004 06:33PM #2
I don't think its an easy mod, it may not be possible.
However, the original version of the ETX-70 was the ETX-70EC, I had one and it is my undertanding that this actually used the ETX-90 EC base. If you can find one of these, the EX-90 OTA might fit. THe difference between the old one and the new one is that the old one has the cable connections in the base where as the newer one has them in fork assembly. The old ones are not common.
But my suggestion is to enjoy the scope for what it is. IF you want something more, it will probably be less expensive to sell the ETX-90RA and buy a working system. The Celestron 130GT seems like the best deal to me in this price range.
jon
Posted 09/02/2004 01:31PM #3
Hi Don,
Here's my conversion:
http://homepage.myeastern.com/~hfs/Projects/ETX70/ETX70.html
As mentioned before, there are two versions of the ETX70. I had both at one time. The one I'm using has a wider opening between the forks. The 90mm Konus just fits (barely).
Harry
p.s. The mount and scope will be on Astromart soon (probably this weekend). Too many scopes. This one has to go. So if you're looking for a base (w/497 Autostar) let me know. I'll make you an offer you can't refuse .
