james carter
North American Nebula NGC7000
Favorite RFTs?
Started by web0178230, 08/16/2005 03:08AM
Posted 08/16/2005 03:08AM Opening Post
[COLOR="Purple"]I love wide-field viewing! In light of the discussion about the definition of RFT, how about some discussion of your favorite RFT.
At various times I've used: an 80mm short tube refractor, a 4.25" f/4 reflector, a 5" f/5 refractor, a 6" f/4 reflector, an 8" f/4.5 reflector and a 10" f/4 reflector. Not to mention various binocs from 7X50 up to 16X80. All have their advantages and trade offs as far as light gathering and portability are concerned.
My current favorite RFT is an 8" f/4 Meade SN used with a Paracorr and a 26mm Nagler giving 36X, with a 5.7mm exit pupil, a true field of 2.3 degrees and stars sharp to the edge of the field. Views of the MW are awesome!
My second favorite RFT is the 5" f/5 which gives 24X, a 5.2mm exit pupil and a 3.4 degree true field of view.
Both of these scopes are used in addition to my main scope when I'm fortunate enough to be able to travel to really dark skies.
Sooooo....what scope do you like for richest-field viewing, and why? Inquiring minds want to know! 8)
Bill in SA[/COLOR]
web0178230's attachment for post 26135
Posted 08/16/2005 04:43AM | Edited 08/16/2005 04:53AM #1
Bill Byrd said:
[COLOR="Blue"]I love wide-field viewing! In light of the discussion about the definition of RFT, how about some discussion of your favorite RFT.
... My current favorite RFT is an 8" f/4 Meade SN used with a Paracorr and a 26mm Nagler giving 36X, with a 5.7mm exit pupil, a true field of 2.3 degrees and stars sharp to the edge of the field. Views of the MW are awesome!
Bill in SA[/COLOR]
Hi Bill,
I agree about the Meade SN scopes, they give a very clean wide field. I'm currently testing a 10" triplet lens stopped down to 9" which gives an f4 system. I can use a 22 Nagler which gets a 5.6mm ex pup, 40X and 2 degree FOV. Stars are not pinpoint to the edge, but at the center FOV they become just pinpoints and filmy nebula and fine grained star fields resolve well.
David Simons's attachment for post 94953
David Simons
Posted 08/16/2005 12:49PM #2
Rich Field scopes...
My current favorites:
1. 12.5 inch F4.06 Discovery DOB used most often with a Paracorr. The field is not as wide as most but it has the cubic inches to do some real damage. Wandering around the Virgo Cluster with a 6.8mm exit pupil at 45x is pretty fine if the skies are dark...
2. Orion Space Probe 130ST. 130mm F5 Newt, has a 2 inch focuser. Nice and sharp at high mags. Have had it over 1200x looking at the double-double. Of course this is wasted magnification but it does work well at high mags.
3. "Burion" 100mmF6 refractor. A Burgess Optical 102F6 fit with ORion Objective. Nice and sharp to the edge. Has the typical advantages of a refractor, no cool down, no collimation no issues with edge of field illumination..
4. Orion FunScope. 3 inch F3.7 Astroscan clone with parabolic mirror. Over 5 degree FOV once the focuser is modified to regular eyepieces. I actually have two of these.. I cut one apart to build a traditional scope out of it.
Rich field is nice, what I like is a Rich Field scope that will still perform nicely on the planets and double stars.
jon
Posted 08/16/2005 01:49PM #3
My Vixen 125mm binoscope- two 5" RFTs in one!
Larry
Posted 08/18/2005 05:53AM #4
My favorite is a 6" f/4 Mak-Newt. A 26mm Nagler gives a 3.5 degree field with stars still pretty sharp at the edge of the field. A view of M31, M32 and M110 all in the same field with a 20mm Nagler was very nice!
