Feedback, Mewlon/AP/TEC
Started by Michael Koons, 04/25/2005 04:51PM
Posted 04/25/2005 04:51PM Opening Post
Just a note wondering......The mewlon 210 looks like a nice fit for my GM-8, any feedback would be nice, the only other options would probably be a Tec 160/AP 160, but if I am reading the stuff correctly the TEC is 50% more than an AP?
Mike
Posted 04/25/2005 04:55PM #1
The 210 would probably fit very nicely on your GM8. The 160 AP would severely overload that small mount. This scope is very different from the 210 Dall-Kirkham. The 160 refractor is primarily a CCD imaging scope which can also be used for high resolution visual. If you want mainly a visual scope, go for a light weight Cass. It will be easier on your mount and your back.
Roland Christen
Posted 04/25/2005 10:39PM #2
"the only other options would probably be a Tec 160/AP 160, but if I am reading the stuff correctly the TEC is 50% more than an AP? "
If I am not mistaken TEC160 comes in two versions, the ED version is a little less expensive than the AP, the fluorite version is considerably more $$ than the AP160. Either of the two scopes are too large for a G11, as for GM8 you can forget it.
Vahe
Posted 04/25/2005 11:47PM #3
Hi Mike,
I recently received a used Mewlon 210 and have been using it on my Vixen GP mount upgraded with wooden legs – works well for visual as long as the wind isn’t blowing! The Mewlon weighs 18 lbs but the weight is concentrated near the mounting plate at the back of the OTA so there’s not much of a moment arm. I’d guess your GM8 will handle the Mewlon somewhat easier than a C9.25 given the weight distribution.
The Mewlon collimation was a little tricky – for some reason I wasn’t able to collimate it adequately using a LaserMax collimator. However, once I got the secondary shadow centered in an out-of-focus star, the scope started performing up to expectation. The LaserMax shows it slightly out-of-collimation but collimation using the shadow-centering technique produced a better image. The laser and shadow-centering techniques agree when collimating my Newts but not the Mewlon.
Even though the Mewlon will work with a GP, my TEC6 is nearing completion and will be a more suitable match for the GP mount. The Mewlon 210 should be a great match for you GM8.
Good luck, Tom
Posted 04/26/2005 02:45AM #4
Mike
I've been using a Mewlon 210 atop a GM-8 for the last year or two. No problem whatsoever in handling the Mewlon. I'm strictly a visual observer, so can't address the suitability of this combination for astrophotography, but for visual use it's fine. I just picked up a Mewlon 250 and Gll, so the Mewlon 210 will soon be for sale on Astromart.
Rob Mackie
Rob Mackie's attachment for post 91021
